i think your right about that. You could get a V8 in an explorer, but not a ranger.10 brakes? if i remember right rangers had the 28, explorers have the 31. but dont quote me on that
the shafts are tiny on a 27 vs a 31 as well as the axle tubes and the outer wheel bearings (at the wheel) are also much smaller.You have 28 spline axles. The only Rangers that come with 31 spline axles are ones with the FX4 package. Explorers to my knowledge only came in 31 spline.
The 28 spline axles are still plenty strong. The shafts are still the same diameter.
I thought the shafts and tubes were the same size, just a lower spline count. *shrugsthe shafts are tiny on a 27 vs a 31 as well as the axle tubes and the outer wheel bearings (at the wheel) are also much smaller.
all explorers 31 spline
fx4 31 spline
http://www.therangerstation.com/tech_library/Axles.html
did you happen to read that date on this post? :fish:Is the cover still on it? If so, there should be an axle tag on it. Maybe you can decode the tag to find out what spline axles it has??????????
LOL! Yes i did. Just thought i'd throw that out there.did you happen to read that date on this post? :fish:
