1 - 20 of 48 Posts
· Premium Member
I'm on my 2nd eaton elocker, the first was replaced under warranty. Took it out today and it would not engage. I had a ton of resistance on the ground coming from the relay (26.3Ohms) so I put a jumper wire on the ground wire, load side of the relay right to the battery and now have my resistance down to 3 ohms on the ground and 2.9 on the positive at the plug that goes into the pig. This isn't too much resistance to prevent it from working, is it? I also have 12.60 volts, which seems more then adequate.
With the front end on jacks, I can spin one of the tires extremely slow, and it will catch and lock up. When it locks, I can push a little harder (I'm talking pretty damn light) and it will click and open back up.
Are these things total junk?? This is the first time I've had it out on the new locker, and I was on a sand hill with basically no resistance and the fricken thing wouldn't work.
Any advice, or should I just try to get Eaton to take back their e-locker so I can get an arb? Internet browsing finds most people love their e-lockers. :(
· Kitten I'm gonna eat you!
I don't think I follow, what was that the resistance on the the locker or the wires or the wiring harness? I wouldn't want tons of resistance on your relay wiring harness because you would not be seeing the voltage needed for latch in the locker. My guess should only be seeing less that a volt at most drop across the relay harness to the locker. Have you tried hooking the locker directly to a 12v source and see if it locks up? That at the very least would rule out poor relay circuitry.
Being I know you and your background in electrical circuits, do you have a break down of the locker itself? You might have something wrong with the interals of the locker.
· yeah, its a barbie jeep
i had one in my old jeep with a ford 44 it worked great till the wires riped out of the pig wich was my own falt my brother in law owns this now. do you have a adress so he can send the locker back to get fixed if so please pm tha dog. thanks
· Visiting Admin
you will not feel a detroit up front unless applying power to it
they dont lock until throttle is applied so if you are in 2wd you wont feel a thing and if you are just normal street driving in 4 wheel drive you wont feel much
· Premium Member
Discussion Starter · #14 ·
oh yeah, I have manual hubs.. So you're saying if I'm offroading and have to turn, I can simply toss the jeep into two wheel drive, and turn?
· Visiting Admin
you can turn with it in 4 wheel they are not as bad as you think they are. i ran one im my old cj and the buggy and rode around in 4 low alot. if i need to turn sharp i would disengage the rear and just use the front
1 - 20 of 48 Posts
