1 - 17 of 17 Posts
sie sehen mich rollin ...
so I have replace my motor mounts and redoing my tranny crossmember, and if I jack up the tranny/xfer case until the carb is level, my driveshaft is all the way extended....
so how much tilt is acceptable for the engine/tranny?
75 cj5 AMC 3-4/TF999/D300
this is just for the rest of the summer, this winter I will be re-doing the driveshaft and giving her a tummy tuck.....
likes him some Red Dog
Doesn't the stock drivetrain have about 3-4* tilt from factory?
...or am I way off?
Discussion Starter · #6 ·
sweet....thanks guys I figured it was ok, just wanted to check first
next question, with that same setup, what would make the output of the xfer case be offset to the driver side about 2 inches? these are brand new motor mounts, have tried 2 different sets of engine brackets.
I compared it to the mounts on my dad's cj with the 304 and both pass and driver mounts are in the same place as his.
frame does not look bent or tweaked, and the mounts measure the same distance from the front of the frame back :confused:
I can get the xfer case to line up with the rear pig if I push it over, but shouldnt it just line up very near perfect on its own?
dana 44 rear btw.....pig is centered
thanks! :beer:
MTU 4x4
I am not sure why it is crooked, but I am sure that 2 inches would not make a difference. A u-joint cannot tell the angle of direction that it is at. It would be like a two inch drop downward....and the u-joint could not tell any difference, if it was side to side, or downward.
2 inches is actually pretty common...plus its a CJ:sonicjay:
What are the engine brackets from? Are you using later CJ, FSJ, or Jeepster frame mounts or engine brackets on an intermediate CJ-5? 76-up is compatible. 75-down is a whole different ball game. If you're mixing generations, that may be part of your issue.
Discussion Starter · #9 ·
they were in the cj with the 304 when I got it, I believe the cj came stock with th 304 :confused:
I also had a set on a 360 I have from a late 70's cherokee that I tried, and it places the drivetrain in the same spot.
goofy
as far as the Carb goes you may need to adjust the float level so you have enough fuel in the bowl.
Hmm .. Motor mounts ...
Wonder if the frame side of the mounts are twisted
How do the Motor mounts look when you push it into aligenment? Do they look to be stressed?
Discussion Starter · #12 ·
yeah they are stressed just a tad....I can push it into alignment by hand, but when I let go it moves back....
frame side mounts dont look outta shape either, but who knows I could be looking at twisted mounts and not relizing it.....let me put it this way, they dont look twisted or anything...the paint is not cracked, and I dont see any signs of stress. :confused:!
I think I may just run it....motor mounts are cheap enough if I fry these ones. :sonicjay:
Mall Rated
The 258 was offset a little bit, and I think the 304 was too, to allow a better clearance for the front drive shaft.
I believe that to be true because in my TJ the output of the tcase was favored to one side. When I was building it and putting in the D300 I just pushed it to be centered and made my crossmember to fit.
In Da Faaaaaace!!!
1988 YJ
ha wana talk about centered engines..... mine is offset to the passanger side like 3" or more to allow my front drive shaft to clear the tranny pan. What a pain that was to move
Discussion Starter · #15 ·
wow....that is offset
just to clarify a bit, my engine is centered, and it looks to be sitting in there straight, it is just the output of the t-case is not in a direct line with the pinion...it is off by about 2 inches.
I just pushed it over and redid my crossmember.
Thanks for the input guys! :beer::beer::beer::beer:
In Da Faaaaaace!!!
1988 YJ
well i had to do that because i'm using the tf-727 with a pan that sticks out the side alot. Also the front d-shaft i'm using is big. So i really had no other choice but to do that lol
1 - 17 of 17 Posts
