1 - 4 of 4 Posts
could you check
easiest is check the diff tag if it has one. or pop the diff cover off make sure the pinion is facing down and count the # of ring teeth and the # of pinion teeth
You divide the number of teeth on the ring gear by the number on the pinion.
1 - 4 of 4 Posts
