1 - 4 of 4 Posts
Big Belly Customs
I just picked up a 92 xj with 4.56 gears in the axles D30/8.25, and i have an 01 xj with 3.55 gears (d30/8.25) i want to swap the gears but don't want to tear them both down just to find out shit wont work.
I haven't had much luck finding info on this subject either.
Cliff notes: will 92 xj dana 30 gears fit in my 01 xj d30?
any input would be great thanks
Just a $900 jeep...
if you have high pinion d30 in the 91 and a low pinion in the 01 that wont work. As for the rear I beleive you're ok, the only difference is the older on has a 27 spline axle vs. A 29 spline axle in the newer one.
Big Belly Customs
Discussion Starter · #3 ·
I know the high/low pinion gears won't interchange, just didn't know if there were different ring gear thicknesses or pinion length/ diameters that may cause issue. My other thought was that if the 92 axle is HP and my 01 axle is LP, could I swap my shafts or at least the knuckles and brakes off the newer one onto the older one without issue?
GL 4x4 Vendors
Gears won't work in D30 because of the high/low pinion issue. Everything else will swap so long as you use 01 rotors with 01 unit bearings.
For the Chrysler, the 2001 will have 29-spline shafts, the 92 will have 27-spline. Gears will interchange.
1 - 4 of 4 Posts
