1 - 19 of 19 Posts
to bad these didnt come up about 2 weeks ago
i woulda bought the in a hurry
Discussion Starter · #5 ·
I like them, but not better than boggers
Yooper In Training
Break twice as many parts as with 18" wide boggers? I'd love to see that happen with any comparable size tire.
Discussion Starter · #8 ·
in the rocks, sticky tires will bite harder than boggers.
Recovering XJ owner
Not to go off topic, but where did you order your double bead locks?
Discussion Starter · #10 ·
all H1s are double beadlocks if you run the runflat in the center. I would continue to run H1s, but I cant get Krawlers or any stickys in a 16.5" tire
Recovering XJ owner
I knew that, but in that case what psi do you run and do you have any issues running the runflats when you air down? I was asking because there are different companies out there that sell inserts w/ out runflats.
PM Lowlock about these too! :thumb:
Discussion Starter · #12 ·
I run 2 psi rear, 5 front
www.buckeyejeepers.com
I would be interested in the rims if you decide to split.
Thanks
Discussion Starter · #16 ·
Discussion Starter · #19 ·
the rims are around 9" wide...
1 - 19 of 19 Posts
