1 - 5 of 5 Posts
In Da Faaaaaace!!!
1988 YJ
Discussion Starter #1
anyone ever do this? I'm wanting to do this for my mopar 360.
when i had the 4.2L and rebuilt it, i welded in a sheet of steel to controll the oil. But it didn't have any one way valves.
I did a search on google and came upong this http://www.brazeauracing.com/oilpan.htm
Looks like BMW uses a stock one way oil valve and gives the part number. I may have to look into those and see if they will work for me.
In Da Faaaaaace!!!
1988 YJ
Discussion Starter #4
well i found a really trick system.... but than again over time sludge would clog it up :(
It uses about 5 check balls. Lets oil only go one way.
In Da Faaaaaace!!!
1988 YJ
Discussion Starter #5
with the Moroso Accumulator , you have to activate it to push the oil out...rite? It won't do it automatically? Also it only holds 2 or so quarts so once those are gone than your shit outta luck?
:edit: It stores pressurized oil that is released when the engine’s oil pressure drops, got that from an article. So it must have a sensor
1 - 5 of 5 Posts
