1 - 20 of 20 Posts
i don't much care for you
I just did a system recovery on my computer.... did I lose everything? if not, where the hell is it all?
it reinstalled windows into the windows folder and thus wiped the registry. as such, if you look in your c:/documents and settings/ folder you will see ( if you chose the same logon name again ) one folder of that name and another of MACHINENAME.logonname. All your old shit will probably be in the former folder.
Discussion Starter · #3 ·
not seeing anything
Discussion Starter · #4 ·
all my documents are gone, my music, my movies, all my work stuff. everything. all my programs seem to still be here... why would it erase all my files but leave the programs?
Try doing a search on your hard drive. Go to my computer, right click on C: and select search. to search for mp3's search for *.mp3 then if they are on your computer still it will state which directory they are in
Discussion Starter · #6 ·
i found a couple things....but it was stuff stashed away in my folder lock
recovery only gives 2 choices. 1 is a full recovery which entails formatting the drive and starting from scratch. The second is a windows folder reinstall which would have left your profile folder intact if the OS is win2k/xp or newer.
Discussion Starter · #8 ·
it is XP. couldnt have done a full.. like i said, i still have programs and a few files stashed away.
so just a matter of finding it all.
well, if you did option 2 your old files should be in one of the profile folders under docs and settings. It don't work any other way unless you did something else.
What you need to do for next time is have a 5-10GB partition for windows, then use whatevers left as a program partition. I've been doing that for years, going from XP to Vista to Linux visa versa.
only problem with that approach is almost all the newer programs install half their settings in the windows folder and thus if you reload the OS partition you have to reload the app from scratch as well.
Then again, most newer programs also default save data to your my doc profile folder so you could use a backup program to simply backup your profile to another drive/partition. This is what I do. 1.35TB primary partition :woot:
Are the programs you are seeing the ones that came with the computer when you first got it? ie buring software, dvd software, MS Works or such? Or are they programs you have added after that?
Discussion Starter · #13 ·
before i did the recovery, i detected a malware i could not get rid of.... then it locked up last night. this morning when i tried to boot up and log into my username it told me it could not detect my profile settings.
thats quite common actually. each profile has a reg file in addition to the computer's master reg file. alot of malware will try and modify the user reg file and corrupt it in the process. Sometimes you can logon in safe mode and fix the issue or delete the profile and create a new one.
In any event, even a corrupt profile registry has no means of deleting your entire doc&set profile folder.
steveo's alt...
Yeah it has it's Pro's and cons, BUT I use a program called Deepfreeze which is awesome against malware and viruses. All you gotta do if you get a virus is reboot your computer, and it disappears!:beerbang:
Discussion Starter · #16 ·
when i try to search for mp3's i dont find any of my music
Discussion Starter · #17 ·
I did some research on the web and found some advice virtually identical to yours.. i followed the advice to the letter and still no dice. I am so lost i dont know what to do
Discussion Starter · #19 ·
i would get a new PC if i was you. something in the 2008s year :tonka:
Thanks for your insight. your advice combined with another 50 cents i could make a call from a payphone. :stan3:
it is actually a computer bought after vista came out.....but like most intelligent people i didnt want vista.
vista, (much like your token of knowledge) is useless and usually creates more problems than it solves.
:poke:
i am usually very good with computers. i used to build them for christs sake...but this is apparently above my head
sɐƃǝʌ sɐן
:poke:
Please dont tell me your using Windows 98 :poke:
cus from Vista to 98 it will not save your stuff
1 - 20 of 20 Posts
