1 - 4 of 4 Posts
The other day my 98 wrangler was working great and I woke up this morning and my cluster,dome light and radio won't work.I have checked all fuses and the connections behind the cluster and I can't figure out why just those 3 things don't work.ANY ADVICE??????
Charcoal Mellowed
Have you tried screwing with the ignition switch while it is running? Is the entire cluster dead or just odometer or backlighting.
I don't have a service manual around for a wrangler but as a shot in the dark guess, I still think ignition switch.
check ur fuses my dash cluster went out and it was a 10amp fuse under the hood, also my radio went out one point and it was also a fuse but it was behind the glove box hope that helps
1 - 4 of 4 Posts
