1 - 4 of 4 Posts
Looking for a CJ wiring harness. If you have just the front part that connects to the firewall junction box and goes to the headlights, horn, etc..that might work as well. I plugged mine back together and now nothing works from firewall to grill. (cleaned and inspectec contacts) Could there be a grounding issue?
rob
Jeep CJ Addict
Rob,
Depending on what you mean by "nothing" works....
There are one and sometimes 2 ground wires that go (anywhere metal) but the stock location is on the inside of the grill near the stock air snorkle on the driver's side and then same spot on the other. It is probably an 8-32 sheet metal screw and nut.... I didn't think it would affect the horn though as that is chassis grounded.
If you put up more details on what you did and what doesn't work, maybe we can help.
Rudy
1 - 4 of 4 Posts
