Looking for a set of wide track axles for a 78 cj5. I think any for 78-86 would work. I would like to upgrade to danas later but would like to swap in some wide tracks while i am swapping springs.
I have some. Could have showed you if you had more time yesterday, as they are all in my storage unit about 2 miles away. They might not be geared as low as the axles you have now, but that may be helpful since your 3rd gear in the T-150 is 1:1 and you may have 3.73's with the 6-cyl. Its all swappable, though. I think all the axles I have are 3.31 or 3.54, but there may be some 2.73's in there also.
Chances of finding a wide-track Dana 44 are slim, as they were only produced for a 1/2 year (late 1986). If you can find one, they usually command BIG $$$. If you want to consider a narrow-track D44, I have one w/3.07 gears that you could run with wheel spacers to match the wide-track width in front. $100.
I also have a set of wide-tracks from this '86 CJ-7 (D30/AMC 20 combo) for $100 for the pair.
As Craig mentioned about the widetrac 44, they are pricey... I do have a factory installed Dana 44 from an 86 CJ7 which is a Widetrac. It has 3.31 gears. I have sold them from $800-$1000 depending on gears.
Thanks,
Rudy
1 - 8 of 8 Posts
