1 - 20 of 124 Posts
Premium Member
So, everyone with a Tom Woods shaft, take them off. They will explode your trans
edit: I am not serious. Tom Woods makes one hell of a shaft. Chrysler warranty people are not smart
The Green Machine
I tried, but my jeep wouldn't move after I took it off. What I am supposed to do so it will move again?
Premium Member
Discussion Starter · #4 ·
Not sure.
My trans issue was caused from the "after market" drive shaft or the body lift.
NO RELIGION WAT!
Actually they are. If they can blame it on something that actually caused the trans to fail then they do not have to warranty it.
You should talk them into blaming aftermarket bumpers instead.:tonka:
Fuck talk, Duck walk!
Not sure.
how does raising the body alter the trans that stayed stationary.
Countryboy
If the driveshaft was out of ballance then it could cause transmission problems.
First in order for them not to warranty the transmission. They have to prove that the modification caused the problem. I highly doubt that will happen. Ussually a driveshaft that is not ballanced will cause a severe vibration and usually cause damage to the transmission casing.
Me balls are huge
NO. Maybe harm the transfer case, but driveline vibes on a 4x4 will never harm the transmission.
Because racecar
I had GM tell me that the flowmasters i put on my 6.0 made it spin a rod bearing :tonka: and they wouldn't warranty it even though it had 12,000 miles on it.... and i replied ok I'll get back to after i consult my lawyer friend... they warrantied it..... twice
wtf are you talking about. An unbalanced DS will never split a case without grenading the internals first.... even then you would have to keep driving it to split a case.
Because racecar
Actually it can crack the case... I've seen them bust bell housings right off of them do to vibration
Wow. Yur smrt. :chiefwoohaw:
Countryboy
Then explain to me why I had a transmission casing crack when the driveshaft started causing a vibration. The T-case is stronger then the transmission and the t-case is attached to the transmission. Being that the T-case is stronger it can with stand the vibrations caused by the driveline better then the transmission aluminum cast casing.
must be a jeep thing, and I believe we are talking about autos
1 - 20 of 124 Posts
