1 - 2 of 2 Posts
I wheel, therefore I am
I have 3 engine blocks that are taking up space in my garage (along with other misc small block chevy parts)
1 Engine casting 330817 and is a CTY engine (400CID) 2 Bolt Main
Comes with oil pan, crank, pistons, connecting rods, timing cover, flywheel, vibration dampner
It came from a Mid 70s vintage Truck. - Over-all good condition There doesn't appear to be any cracking in the casting anywhere.
Asking $175 as is
1 Engine casting 3970014 and is a CT1 engine (350 CID) 2 Bolt Main
Comes with Crank and pistons / connecting rods, timing cover, oil pan, vibration dampner
It came from an early 70's Camaro - in good shape (slight rust in cylinder walls that could be honed out)
Asking $100 as is
1 Engine casting 3970010 and is a CMJ engine (350CID) 2 bolt main
Comes with main bearing journals and block is in need of an acid dip to be useable (corrosion in cylinders)
It came from a 1974 full size car / truck
Asking $50 as is
Several Rochester 4bbl Carbs and 1 2bbl carb - some assembled some not.
Asking $50 for all of them as is
If you want to look at them or have me send you pictures please e-mail me [email protected] I am in waterford
1 - 2 of 2 Posts
