1 - 20 of 22 Posts
Hi all. New here and allready asking for help. I bought a 2001 wrangler from my brother and only problem with it is that the check engine light comes on everytime It is gased up. He took it in and they got him for 500 bucks for a new catalitic converter and that didn't help. He bought a new gas cap and that didn't help. They would just reset computer to get light to go out and leave it at that.
Anyone know what may cause this and is there a easy fix. If I want to get light to go out without hooking it up to the computer is there a way to do it. He tried unhooking battery and that didn't do it but said he may have not left it unhooked long enough.
Anyhow great site and am looking forward to many hours of good reading
thanks
Rick
make sure you tighten the gas cap properly. if it happens every time you gas up, it's either that, or you're leaving the vehicle running while filling up.
also, if you're gonna post that you have a code, it's not gonna do much good unless you can tell us which code. go to autozone and have them pull it then post back.
circling the drain
Turn the key on/off three times. The code should display in the odometer. Search for the code online and voila.
Do that, then read this thread. I am having the same issue, I found a small leak on my filler neck which I believe to be the problem.
http://www.greatlakes4x4.com/showthread.php?t=52865
There is a list of codes in a post by sandals.
Odd...I bought my 2001 jeep from my brother with an intermitten check engine light also.
I thought emissions equipment like convertors were covered under warranty for up to like 7 or 8 years or something? You might want to call DCX Customer Service and ask about that.
8 years / 80,000 miles. Covers PCM and Cat., some other items.
Get us a Fault code and we can be much more helpful.
Again, Autozone gives free checks for the fault.
do you have to go to the dealer to get them warrantied??? somehow i got a feeling that even if it's only 4 years old and you pull into a midas or whatever exhaust shop and willingly pay them for a new cat, that they don't give a crap about warranty.
Uh, yeah - because DCX warranties the vehicle.
The way he wrote "took it in" made me assume he took it to a Dealer, because most decent shops would probably have checked the code and told him what it said. Most non-OEM shops I've dealt with are more generous with info. The $500 price tag on a converter replacement also strongly suggests a Dealership, too. Well, at least to me it does.
Discussion Starter · #15 ·
Thanks for the help all. I didn't know the code nor how to find out but I did the key thing and it is p0432.
The jeep has 100,000 miles on it so warranty over.
I like the black tape idea myself.
thanks again
Buy a Fiat! Save the UAW!
I think I know whats wrong. if its only doing it when gased up then I would check the purge vent on the charcoal canister for mud blocking the vent. if its not venting it will toss a code.
by the way if your one of those guys that has to get every last drop in the tank by clicking the pump handle over and over it will do it to. it over flows gas into the canister
Uggh
will it throw that code if the downstream o2 is bad?
1 - 20 of 22 Posts
