1 - 17 of 17 Posts
hug life
Discussion Starter #1 (Edited)
I was going to go with a buggy then life happened and im out.
This could be a good start for someone looking to build a buggy.
only the belly is welded together
all other either barely tacked or not at all.
the tubing is dom
200$ OBO
hug life
Discussion Starter #3
I was going to be running a cj front end with a chevy V8, auto, Dana 300 and one tons if that helps you.
the tube for the rear is not there and not bent yet so you could change some dimensions with that
here are a few dimensions. Let me know if you need anything else specific
It was designed for Trailgear Creeper Joints.
If you buy it from Robby I'll give you the 3D Pro|E model.
There's also a D60 front truss and lower link mounts and D70 rear mounts designed to go with the geometry of the buggy. Not sure if Robby has those listed separate.............
6'-5" 209LB 16YR LEFTWING
I'm Intrigued! I will have to see how the cash flow is in a couple weeks and if it is still here. I have a few other things to pay off first.
1 - 17 of 17 Posts
