1 - 7 of 7 Posts
Adrenaline my drug choice
backed out of my drive way a little hard on the gas and the pinion got sucked in to the ring gear and locked up. never seen this before. check it out
Not Right!
So did the nut fall off? Looks like you stripped it removing it and you just lunched you pinion bearing? Have you worked on it recently?
Discussion Starter · #3 ·
this is my stock 99 tj i have never had it apart. it striped nut when it broke or maybe when it was put on new cross threaded ?
Discussion Starter · #6 · (Edited)
any one have any 4.11 gears d35
not needed now 8.8 half way in
Discussion Starter · #7 ·
the 8.8 is in that was fun
1 - 7 of 7 Posts
