I'm in the middle of swapping my rear drums for discs, and am looking at the lines....
I could just screw the stock hard lines into the caliper, but the placement of the calipers moves the fitting about 2 inches closer, so I'd end up with too much hard line, so I going to make shorter lines..
Geometry wise, its easier to run the hard lines over the top of the spring pack/plate, instead of under the spring, then back up to the caliper..
Other than the obvious thing about needing to remove the line when taking the axle out of the truck, is there any other reason not to do this.
Just checking if there's anything else Im forgetting, since you don't often see people do this setup.
