i have a 88 dodge dakota 4x4 3.9 ,
the brakes lines were all rusted pretty bad, so ive changed all the brake lines from master cylinder to rear of truck and new wheel cylinders on rear, i put in new lines from master cylinder to the first servo thingy, i did not change teh front lines as they all looked like they had already been changed at one time, i also put new caliper both sides on front. my problem is, that i have good pressure during bleeding in teh back, but no pressure on front wheels during bleeding at all, it will drip fluid but doesnt blow it like it should when bleeder screw is open and pedal is depressed.
no i figured it might be the rubber lines plugged so i disconnected the right front side. blue compressed air through it and air came out other end. so im thinking the rubber lines arent my problem,
so now i need advice as to where to go from here,
im wondering fi it could be the servo thingy thats pluged up or something,
servo thingy = the device where the master cylinder lines
go in and then the back end line goes out and the front line goes out.
please help im desperate.
thanks for any advice i can get
