Should be 3/8" and 7/16", depending on position.what size diameter bolt is used for mounting jeep body to the frame? and grade for that matter
Thanks
I'm not sure why you'd use carriage bolts, the bolts go up from the bottom and the nut is located inside the body channel.thanks for the response I just picked up 7/16 for all mounting points, got carriage bolts and I am going to look for some square sheet metal with squares punched out for locking in the carriage bolts. unless someone knows where to get these premade
