project plan is to take a two door blazer do a sas put with narrow axles. Trying to keep it low and capable. planning to run 35-38" tires
Parts to be utilized consist of:
two door blazer/jimmy
5 speed maual
np231/d300 doubler
waggy 44 front with chevy flat top knuckles for highsteer
toyota rear
basically im going to start small and build bigger as $ allows, stuff breaks, or figure out what will work better.
Would like to have the front linked, a flat belly, and exo cage to keep the body straight enough for the doors to open and shut. Going to have the axles locked and have chromos in the front atleast eventually. also wouldnt mind getting the heat and ac to work but thats at the end of the list of stuff to get working. Once i get this phase done and the bugs worked out im going to wheel it and figure outwhat to do from there. Im looking to join a relatives and friends in their wheeling trips to canada, R&V, Badlands, Twisted trails, and local trails.
This build is inspired from some of the things i learned from my 4door build that i scrapped/parted out.
http://www.greatlakes4x4.com/showthread.php?t=244147&highlight=
5 speed maual
np231/d300 doubler
toyota rear
