1 - 20 of 35 Posts
Discussion Starter #1 (Edited)
Hey all! Long time lurker here, figure it may as well be time to start contributing. so why not, let's make a build thread or two! Tried to start one on fourdoorbronco.com, but it hasn't popped up yet.
About a month ago I purchased my C350 Centurion Bronco (this one) and have been tinkering with it since. It sports a 460/E4OD/manual shift tcase.
I've always had a fascination with these things. While working out of country, I was browsing craigslist and stumbled upon this guy. why I was on seattle craiglist is now a mystery to me. I had been wanting an OBS f250 or F350 to meet the towing wants that the little SCSB 4.9 truck isn't meeting. Got ahold of the guy the first or second day it was posted on craigslist and and after a little back and forth we started the motions of getting it bought. That proved difficult while working in Brazil, truck being in Seattle, and living in Michigan. First rodeo like that. To shorten the boring part of the story up, I had it shipped and it arrived the day after I got home from the 5 week work trip. All was good with the world.
Here it is on day one:
We figured we'd put a few tanks of gas through it and then start on the roof repairs. Here we are 6 weeks later and we've put about 2,500 miles on it. It's been across the Upper peninsula twice to the LOORS and plan to take it to the races for Crandon's 50th.
From there, we plan stab it into the garage and start on the roof repair and the few other body issues over the winter. It is a very clean truck other than the roof seam and a few layers of paint. Roof doesn't leak right now, so i'm optimistic, but preparing for the worst.
Not really ever going to be an offroader, but will hopefully be towing the jeep(s) and whatnot around before too long. :thumb:
Discussion Starter #2 (Edited)
[hopefully the pictures are working, they appear to be on my end]
Since taking it in, we've gotten some of the smaller things out of the way in between trips to the lake:
hauling 12 foot boards with the tailgate up:
hauling home 14ft steel for the new roof:
The first change was to fix the tan center seat that was stuck in the up position and had no cup holders! LAME! I happened to have a 2015 F150 center console (planned to use on another truck before impulse buying the centurion) so it got mounted up to the conveniently placed center seat mounts. That grey panel drives me nuts, so it'll turn tan when I ditch the BMW seats.
Before: (PO picture)
After:
Discussion Starter #3 (Edited)
The PO mentioned that the trans shifted hard. boy was he right. Often times it wouldn't even downshift into 2nd or 1st, forcing manual shifts. Often threw trans codes indicating the solenoid pack wiring to be at fault. tore into it one evening and found the harness to already be replaced.....with crimped on bullet connectors. cleaned everything up with solder and adhesive heat shrink and now it shifts consistently, albeit still harder than I'd like.
While I was under there, i cut the 3D printer loose and whipped up a switch mount to fit a Torque Converter Override switch. Down is computer controlled, Center is Forced Unlock, and up is Forced Lock. Forced lock is nice on all the two-lane highway roadtrips across the yoop. Forced Unlocked is nice around town as it keeps the confused torque converter out of the equation at lower speeds. Ultimately makes no difference unless you're really paying attention to how the torque converter acts. Still pull a whopping 10-11mpg. While I was in there, I replaced some worn switches and found some good work by centurion mounting the bullnose bronco switch in the areonose dash.
Found the oxygen sensor plug good and melted while crawling around underneath it:
Which explains the extra plug under there:
Premium Member
I can only see the picture labeled day one. Good looking truck, I'm looking forward to following your thread fro updates.
Discussion Starter #7 (Edited)
eff, i'll try to get that figured out. Trying to link from Google Photos with little success.
Edit: got the process down for photos. back to the show!
Discussion Starter #9
Figured I should go through the boxes of parts the PO sent with the truck. found some solid gold!
So that do-nothing chip was plugged in immediately. lol. Gotta see if I can still cash in on that free t-shirt. :naughty:
Discussion Starter #11
The first drive across US2 at night was pretty terrible. The headlights were aimed way too low and the light output was lackluster. Couple that with rain near escanaba made for a fun few miles.
I had been wanting an excuse to HID projector swap something for quite a while, and this was as good a reason as any. Ordered up a set of ebay housings and amazon projectors and got to work. The swap was extremely simple and only took a couple evenings. The light output with decent HID bulbs and ballasts is incredible. The low beam cutoff is really nice too. All much better than just stabbing LED bulbs in and blinding everyone on the road.
pay no attention to the constant CEL. We're workin' on it.
Haven't taken any more photos of the truck with new headlights during the day. Guess i'm going to have to.
Discussion Starter #15
Thanks everyone! I'm a pretty big fan despite it's current issues. Couple more updates will bring this thread up to date.
This next bit is not nearly as fun. I replaced the muffler and rusty/holey/about-to-fall-apart tailpipe, which apparently the passenger exhaust manifold didn't like. Started leaking terribly at the rear port against the head right before the trip to Bark River International Raceway. That was top of the list on sunday. Read up on it and found that it's a common problem for the 460.
WEEEEEELLLLLLL, now the head has to come off. so much for that one sunday afternoon project. Grabbing a gasket set on the way home today. I am lucky enough to have my ford enthusiast grandfather who had a set of EFI 460 heads and manifolds sitting on a shelf right next to the window motors I needed for the back doors. grabbed them on a whim on Saturday. Sure glad I did!
Was reallllly tempted to order a new cam while I already had the top of the motor apart, but I am trying not to sink a whole lot of money into this drivetrain because.....reasons. That and we leave for Crandon next tuesday.
updates on that nonsense to come.
Huge bronco fan, I’ve owned several and always wanted a centurion but never could justify it. They are cool for sure. So why ya gotta pull the heads? I suspect a broken manifold bolt. There’s a lot easier ways to get em out without pulling heads if In fact that’s the issue.
Sent from my iPhone using Tapatalk Pro
Discussion Starter #18
Broken stud flush in the back hole. Tried welding nuts to it: no dice. Tried Drilling: couldn't get a straight line on it, broken bits. Tried torching: messed up outer few threads before calling it. Figure it's not a huge deal to pull a head off and get a better idea.
I did realize yesterday that the truck has F3TE heads and my replacements are E7TE's. I'll try to salvage the F3, but not going to hold out much hope.
This thing's pretty cool!
I miss going to the races at bark river and crandon.... it's been too long
It's not too late to go again! The 50th is going to be good. Top will be coming off the bronco for the trail ride on the original 1969 Brush Run 101 course!
Gustafson
For those of us who are not hardcore Ford aficionados, what does this mean?
Discussion Starter #20
Man, I wish I knew more. from what i can tell the E heads have a slightly smaller intake valve and a slightly larger combustion chamber.
all I know is what i read on the interwebz last night. They can't put anything on the internet that isnt true, amirite?
1 - 20 of 35 Posts
