With the way that people are wheeling their JK's now bent axles are all too common. One common point for the JK front axle to bend is at the inner C’s. The Barnes 4WD JK Inner C Gussets will prevent this from happening. These gussets will work on your JK no matter if it have a Dana 30 or if you have a Rubicon with a Dana 44. The gussets are cut from 100,000 tinsel strength steel and are cut to be a precise fit to your axle and inner c.
