1 - 7 of 7 Posts
Hi
I am barely getting 12 volts out of my jeep. Any suggestions (other than new alternator) as to the problem??
83 cj7 258
rob
:usa:
Can't lose with 42s
.....external voltage regulator?
Discussion Starter · #4 ·
12 v
not sure about the external voltage regulator, but, i will check the wires ...
thanks
rob
Flat Fender's Forever
The Alternator should be a Delco with an internal regulator, make sure the belt is tight and in good shape. Sounds stupid but I have seen it fool people. Check the volts coming out of the Alternator and compare them with the Battery voltage should be close. If all this checks out you probably need a new Alternator.
Jeff
What dunedog said. Check alternator output to ground, then positive to negative on battery.
Are you seeing the 12 volts on a DVOM or on the I/P gauge?
1 - 7 of 7 Posts
