How difficult is it to do it yourself? I have a '93 GMC Sierra Z71. I was just quoted $530 for one side upper and lower ball joints. I am pretty sure the parts are not that expensive and how much labor am I looking at?
you need a better air hammer or air supply then...I have used an air chisel to take out many rivets, and the ones in the balljoints are usually out with just a few hits...frame rivets take a bit more, but I have cut them out with an air hammer and good chisel bit toosome people say you can use an air chisel to chisel of the top of the rivets (BULLSHIT)
I was using a Ingersoll Rand chisel with a 60 gallon compressor set at 150psi with a sharp chisel and it would not even dent them let alone cut them off. they was tough rivets, it took 10 to 15min per rivet using a die grinder with a carbide bur bit, there was not enough room to get my drill in there to drill the top ones so that was not an option.you need a better air hammer or air supply then...I have used an air chisel to take out many rivets, and the ones in the balljoints are usually out with just a few hits...frame rivets take a bit more, but I have cut them out with an air hammer and good chisel bit too
wear a face mask though. trust me. go to the hospital once to have the head of a rivet taken out of your cheek and you never do it without a face mask again.
i used to do them every day the rivets come right of with my air hammerI was using a Ingersoll Rand chisel with a 60 gallon compressor set at 150psi with a sharp chisel and it would not even dent them let alone cut them off. they was tough rivets, it took 10 to 15min per rivet using a die grinder with a carbide bur bit, there was not enough room to get my drill in there to drill the top ones so that was not an option.
As for tools for the OP you will want a Pickle Fork to go with your hammer and wrenches.
