1 - 4 of 4 Posts
Jeeper
Looking to replace the 32rh with the AX15.
I need the following:
Ax15 trans
Bell housing
Clutch pedal assembly
Cms
Css
Premium Member
I have a complete 1995 YJ here right now with the AX 15. I would sell everything that is needed to do the swap but not sure how long it would take me to remove it all. Now if you wanted to remove everything yourself it would probably be faster.
Jeeper
Discussion Starter · #3 ·
That sounds promising, are you in need of an auto trans?
Premium Member
I have absolutely no use for an auto trany. I did talk to a guy this morning though that is looking for one right now. I think the biggest issue that you are going to have is all the parts you need will be pricey. You are going to need the transmission, steering column, drive shafts, linkage, and I am sure some other misc. pieces. You might find it cheaper to just buy another complete Jeep with a rusty frame and take what you need than sell off the left over parts.
1 - 4 of 4 Posts
