1 - 20 of 25 Posts
I have killed my second optima yellow top battery. It gets a full charge but under load drops under 5. I read all the threads I could find and tried different charging techniques to no avail.
I am not sure if I want to get another optima or not. Something that is not used all the time. And I use a trickle charger.
Courious what kind of battery you use.....
Better than Newbie
got a yellow top here... on my second one. my original died after 5 months, just out of nowhere... would show good voltage, so I think i took it in for a quick test, and showed up fine, but then swapped with a different battery and it worked fine, so I took it back and they did a long test and then replaced it for me for free
Fucking Zen as Shit
I have a red top in my WJ, going on 4 years now without issue.
Yellow top in my YJ I am on warrantied #3
Discussion Starter · #9 ·
I want to know what kind of battery everyone is using know. Not yeah they suck, I wouldnt buy one.
Theyre terrible. My 4cyl s10 killed a yellowtop! I traded mine in a sears and got theyre second cheapest one and $70 back and didnt have any problems afterwards.
wow really ?
I bought a yellowtop for my xj in 2003 and I beat the piss out of that thing it works as good as the day I bought it.
Leave the dome light and cb on overnight, no problem, headlights and stereo on for hours, no problem, alternator dies everytime you wheel, I can run for about 6 or 7 hours before it finally dies. and each time charges up no problem.
Premium Member
I've drained the Red Top in my tow rig maybe a half dozen times and it always comes back with the trickle charger. I don't think it has the life it used to though.
The Yellow Top in the YJ is going strong. Both of them are 2004 + batteries.
I just swapped out my red top last week. The battery would always read 10 volts and evenn after running for 4 hours, after 3 minutes would drop.
I took to murrays and they swapped it out for an exide that was worth 25 more than my redtop
i am in the same boat i want to buy a "offroad"batery and want to know what people use i know there are alot out there and dont want a optima
My 87 yj has a "Sams Club" marine deep cycle battery. Total cost $56.00. I usd it in my motorhome as a "house battery" for 2 years. Then transfered it to the YJ when I need one in there. Been running strong. Jeep sits in the wintertime in an unheated garage and only starts up every month or so.
I went through three yellow tops, all covered under warranty. I went to warranty my fourth, and murrays no longer carrys optima's. They gave me some other battery thats supposed to be the same, it looks like an optima. I don't remember the name.
Its worked fine since the builds been done
i have looked at the odyssedy and procomp and seam to be avout the same price as optima im thinking i will prolly go with onw of those...anyone have any luck or use one??
sorry for the thread jack but at least we staying on the same topic
I've always ran the Autozone Duralast (3 year free replacement) and had good luck. I switched to a Blue Top Two Summers ago and have had no issues, even after a complete drain. I only jump started it. Still working fine.
1 - 20 of 25 Posts
