You would recommend a cordless for fab work? Why is that?We have a cheapo home depot brand that I aquired free...so far so good. I would recommend a cordless for fab work tho.
Dumdum can't figure out how gravity works with electrical cords?You would recommend a cordless for fab work? Why is that?
Have you used one with the autobalance? It seems like a nice idea that would be easier on the bearings and cutoff wheels but c'mon it's used to cut metal not slice butter. Does it matter?If you got the extra cash I would get the 6". The larger wheel is very nice.
I have never used one but it would be nice if it actually works. The vibrations from a grinder can be rough on your wrists over time. That may not be an issue for the average user but somebody like myself that uses them a lot it is a big deal.Have you used one with the autobalance? It seems like a nice idea that would be easier on the bearings and cutoff wheels but c'mon it's used to cut metal not slice butter. Does it matter?
https://www.youtube.com/watch?v=JnrwNDzBf94
Suck it up Nancy. My dad and grandpa haven't used them in the 90 years combined. Their hands aren't the problem.I have never used one but it would be nice if it actually works. The vibrations from a grinder can be rough on your wrists over time. That may not be an issue for the average user but somebody like myself that uses them a lot it is a big deal.
Carpol tunnel (sp?) is a big issue with pipe welders. I know multiple that have had to have their wrists done and the doctors told them that grinders were probably the reason.Suck it up Nancy. My dad and grandpa haven't used them in the 90 years combined. Their hands aren't the problem.
Huh, either they don't do grind enough to get that, or they are bamf'sCarpol tunnel (sp?) is a big issue with pipe welders. I know multiple that have had to have their wrists done and the doctors told them that grinders were probably the reason.
That is the thing with pipe. You bevel, tack, grind tacks, root, wire wheel root, grind root, grind your start on your hot pass, wire wheel hot pass, grind your start on the cap, wire wheel cap. Them repeat...Huh, either they don't do grind enough to get that, or they are bamf's
Ours come from the welding supply store. Hardware store wheels suck.Were is everybody getting wheels from? I've found the wheel makes almost as much difference as the grinder.
It is a ways off from you but Performance Tool on Tele has them. I've had a craftsman for 30 years but noticed the housing was cracked this summer after I put a cup brush on it.Still works but bought a cheap HF for now. I have a big Milwaukee for serious grinding.Where does everyone buy their metabos? We've had good luck with dewalt and Milwaukee.
Metabo 4-1/2" ftw. Thrown in the dirt, sand mud snow, cold as fawk hot as fawk, I have cut thousands of pieces of bar with it and done more rubbing and patching walls than I care to recall. I bought mine at ace cutting in novi about 5 years ago. Expensive at first but a worthwhile investment considering I probably would have burnt up 5 or 6 dewalts by now.(I smoked two in one season prior to the metabo):thumb:
