1 - 14 of 14 Posts
· 10 Years
99 Cherokee Classic with approx 125k on it. Has power windows/locks/mirrors, cruise, A/C (blows cool, not cold, could use a recharge). Has a 3 radius arm long arm lift with 3.5" Rubicon Express springs front and rear. Tires are 31x10.50x15 Goodyear Wrangler RTS' with about 50% tread remaining. The jeep has newer front brakes, right side wheel bearing and axle joint, air filter, etc. Radio is a Chrysler factory CD player. The body is in good shape, it does have some dings and dents here and there, but looks pretty good cleaned up. There is rust on the passenger side rocker panel but the floors are solid. Interior is in good shape with no rips and no holes in the carpet. It runs and drives good. The check engine light is on due to the downstream oxygen sensor. The sway bars are currently removed but I do have the front to put back on if you would like it and there is a crack along bottom of windshield. The rear axles is starting to make some noise which I believe is coming from the pinion bearing, but I have a replacement rear axle that goes with it. It will also need the front driveshaft rebuilt or replaced. The trackbar was recenlty rebuilt, new steering stabilizer and new shocks all around. It also has a trailer hitch and front tow hooks (not pictured). Drives good for a lifted Jeep.
Looking for $3300 obo. *NO TRADES*
More Pictures
1 - 14 of 14 Posts
