1 - 5 of 5 Posts
Im looking for a 97-99 TJ radiator that is for a manual transmission. I dont believe it matters if it comes out of a 2.5 or a 4.0. Can anyone elaborate on this?
I think the only difference is the 4.0 has more cooling fins.
new aftermarket they come out as the same part number. doesnt matter if 4 or 6 or manual or auto they all use the same one. 4cyl 87-01, 6 cyl 87-04
sorry pressed enter too quickly, i work at a salvage yard and don't have any used right now but can get a new one shipped to you for my cost-$110.
Low Range Drifter
I still have this one for sale. $75
Original OEM Radiator from an 01 TJ 4.0 Manual with < 60,000 miles. No leaks. Removed for an engine swap.
Will fit in any 1997-2006 TJ with 4.0 and manual transmission. Not direct replacement for 4.0 & auto since it has no trans cooler.
Comes with fan shroud that is cracked at the bottom, could easily be patched. The shroud is from another TJ that we swapped my engine into, and they wanted my shroud.
http://www.greatlakes4x4.com/showthread.php?t=112378
1 - 5 of 5 Posts
