Modified post. Everything I wrote in this post is what the Original owner had said was done. I am skeptical about a cam due to the fact it doesn't have the cam lope that I've seen on LT1s on Youtube with said cam. The crank is unknown to be a 400 crank. But I do believe if it did have a 400 crank there should be some sort of cam lope correct? We took my buddies scope and scoped the cylinder and the top of the piston does say .030. so it is verified to be .030 over. Exhaust is obvious. MSD Wires and Coil can clearly be seen.
1995 LT1 Z28. 98K Original
T-Tops. 6 Speed. 350 with 400 Crank, .030 Bore, LS1 Aluminum Heads, LT4 Hot Cam, SLP Loudmouth Exhaust. Stage 3 Clutch, 2000+ Camaro Rims, 3" Cowl, Power seats, windows, and locks, EVERY Thing works as it should, MSD Wires and Coil, K&N CAI, Every gear shifts perfect. B&M Shifter, Car is FAST, and Loud, 4.11 Posi Rear End, Drilled and Slotted Rotors, Street Agressive Tune, MAF Mod, Cars pretty sick with it.
Looking at trades. Or 5,900...
