1 - 20 of 25 Posts
91 Jeep Wrangler with super solid frame and body. Body has dents but no rust anywhere or ever. It has a TBI Chevy 350 with new oil pan, pan gasket, distributor, cap and wires, plugs, water pump, alternator, belt, aluminum radiator, and more. Runs great. Trans is a turbo 350 auto with a 231 t-case behind it with SYE. Has new shocks. Has a dana 60 rear axle welded with 4:10 gears and 5 on 5.5 bolt pattern. Will also toss in a LSD for the dana 60. Front axles is dana 44 with 4:10's and LSD, new axle u-joints, warn lockouts, and new brakes. New gas shocks. Front suspension is Ford radius arms with coils and the rear is XJ leaves. It has 37" Boggers on it with 90% tread.
The bad: Trans dipstick leaks at trans (rubber O ring is bad or missing)
DOES NOT COME WITH WINCH OR FRONT BUMPER!
Located in Marlette MI
Price is $3200 with the boggers
Or $2500 without boggers and will come with rollers
These prices are firm unless you want me to take more stuff off the jeep.
Discussion Starter · #15 ·
It runs perfect. As far as how it drives? I have only put about 10 miles on the road with it but im putting a new adjustable trac bar on Monday and switching some stuff so ill take it for a ride and try it out.
1 - 20 of 25 Posts
