1 - 4 of 4 Posts
MT. Dew- Mudders drink
HELP!! I have just replaced the fuel pump and filter. all went well, no bolts snapped or gas lines and most of all no explosions!!!
However, the fuel relay is stuck, Click,click,click and when I pull out the relay it stops. This is when the key is in the start position and of course it wont strart either.
When we first changed it (the fuel pump) It started right up and ran really good after the air got out of the line for about a half hour and then started sputtering and died. Now it sounds like its not getting fuel again I thought it was the fuel pump? Maybe I had a different problem??. Has new battery turns over great. Oh,. I have already replaced both of the relay switches that were over there together. New one does the same thing.
All I want to do is go play- frustrated- I have new tires and rims and can't get out of drive way HELP!!!
Chillin with the top off.
Make sure you reconnected your ground.
1 - 4 of 4 Posts
