1 - 3 of 3 Posts
DPS Diamond Plate Special
1988 Sport Truck pick up truck. 2 wheel drive. 4 cylinder automatic. Good tires. Body looks bad (dented and rusted), but starts, stops and goes. It has 169,000 miles and runs but chugs. It has a lot of blow by and will spit out some oil from the dip stick tube and valve cover breather - possible bad piston rings or some such problem. No radio. It does drive however. The trans seems fine the brakes are decent. I just need it gone. I need it out of here quick. Many good parts if you wanted to part it out. Or, might make a good farm or work truck.
Located by Union Lake rd and Cooley Lake rd south west of Pontiac Michigan.
First $275 drives it away...
Dan 248-895-1444
1 - 3 of 3 Posts
