1 - 6 of 6 Posts
AS-IS is AS-IS!
OK Sami folks, here is the deal of a lifetime! This is a RARE, make that VERY RARE '87 Suzuki Samurai! Why rare? Well, for starters, it has ONLY 68K ORIGINAL MILES, it has NO body rust, NO frame rust and best of all ... it sports a Camden Supercharger!!!
The Mods:
- SUMOII Head & Cam
- Camden Supercharger
- Weber 32/36 w/Extra Jets
- RAMFlo Air Filter
- Swift GTi Oil Pump
- Calmini Ceramic Coated Header
- Rotational Dynamics Adj. Cam Sprocket
- MSD 6-BTM Ignition System
- MSD Hi-Vibration Blaster Coil
- NGK Wires
- New Cap/Rotor/Plugs
- Trail Tough Hi-Flow Exhaust System
- Poly Shifter Sheet
- Poly Transfer Case Sheet
- Rocky Road SPOA w/Z-Link
- Energy Suspension Poly Bushings
- Rocky Road Greasable Shackle & Main Bolt Kit
- Trail Tough Shackles
- Red Ryder Shocks
- OME Steering Stabilizer
- Spidertrax Rear Disc Brake Kit
- Spidertrax Adj. Proportioning Valve
- Spidertrax Rear Brake Line Kit
- Optima Red-Top Battery
- American Racing Aluminum Rims
- BFG 31x10.50x15 AT's
- Trail Tough Front Stinger Winch Bumper
- Champion 8,000# Winch
- Trail Tough Rock Sliders
- Trail Tough Rear Bumper w/Tire & Gas Can Carrier
- Split Second Air/Fuel Ratio Meter
- Cobra 25 w/40W Mod
- Firestick CB Antenna on Spring Mount
- Designs Of Steel Driver Side Windshield Hinge Light Mount
- Hella Work Light
- Designs Of Steel Complete Interior Poly Panel Kit
The Bad:
1. It has a small oil leak on the oil pump gasket. Nothing major, but it needs fixed.
2. It needs a carb tune-up BAD! Runs fine except for high idle when choke is on, when choke turns off, it has problems staying running.
3. I would HIGHLY recommend a Water Temp. & Oil Pessure gauge before driving it regularly.
4. Master Cylinder Reservoir needs new o-rings.
Why am I selling this gem? Well, this makes vehicle #4 for us. With the new baby and a possible move in the future, I need to thin the herd. That and the lift and bumpers for the FJ are expensive ... using the money from this to mod the FJ and use that as my wheeler. Can't afford to pay tax and insurance on another vehicle I never drive!
ASKING $6,000 ... YOU CAN'T BUILD IT FOR THIS!!!
AS-IS is AS-IS!
Discussion Starter · #5 ·
bump ... need to sell ASAP ... make me an offer!!!
AS-IS is AS-IS!
Discussion Starter · #6 ·
Sold!
1 - 6 of 6 Posts
