1 - 2 of 2 Posts
Martial Artist
Discussion Starter #1
Hello all,
I recently purchased a 85 CJ-7 and have a few questions regarding it.
1) Any idea what manual transmission I have? (not sure where to look to find this)
2) Why is the flywheel exposed? Is this normal? How can I go about covering it?
3) Is the amc 20 rear axle with yukon single piece axle shafts solve many of the issues with that axle?
277940
277941
Low Range Drifter
I'm guessing you have a 4.2? Based on aluminum case, drain plug, and hoping nobody swapped in something different; I would guess it's a T-176.
You are missing the inspection cover. I found a repop on ebay. Might also be available from Quadratec, 4 wheel parts, etc.
AMC20 with aftermarket axles puts it in the same category as the Dana 44.
1 - 2 of 2 Posts
