1 - 10 of 10 Posts
· Registered
I am pulling my old rusted tub off and while I am there I am going to clean up frame, etc. Included in that is replacing the brake line, fuel lines, etc. Questions is, where do I get replacement brake lines that I do not have to cut and flare?
· Web Wheeler :(
that would be hard if you don't want to cut and flare your best bet would be measuring about how much you need and go to a parts store and buy that many in inches but the catch is you will be using connectors and adapters. its all good if you don't mind the look of the connectors. you will be bending the lines yourself also.
· GL 4x4 Vendors
Sweet, so is that the complete replacement set, minus the flexible lines of course!
Yes, master cylinder to proportioning valve, from front to rear. Just add flex lines (no hard lines included for the axle, either).
I used it when I rebuilt mine.
1 - 10 of 10 Posts
