1 - 17 of 17 Posts
The Biohazards
*** $1000 Takes it all otherwise I will part out ***
I have a 1975 Ford F-250. The truck is from California, body is in decent shape. Comes with basically everything to convert to 4x4.
The truck sat for a few years a friends house. It needs front wheel bearings and the fly wheel is cracked so it sounds like it has a knock when in park or Neutral. Truck also leaks some fluids when running. Not sure where they are coming from, I never investigated it because I was going to big block it.
Additional Items:
78 Ford 4x4 frame which I kept for reference to look at reference points when doing the conversion. The frame has all bracketry for the 4x4 conversion.
Ford 460. I have never heard it run so I have no history... bought from someone else on the board.
(2) C6 with the 4x4 output tail ends
2 extra radiators
np205 transfer case including the in cab hump plate
Dana 44 front axle
Would like to sell as a package. $1500 obo takes all which is less than what I have invested.
Located in Waterford
Selling because I need to build a garage before I undergo this type of project.
Nice body the doors look good and the front end is pretty. I don't think that the 76 grille that I have looks the same the plastic parts don't extend outside of the headlight buckets interesting.
I don't have the room for the whole truck if you consider parting it out in the future let me know.
The Biohazards
Discussion Starter · #12 ·
If someone dont buy the whole thing by this weekend I will end up building this in two stages...
Put in the big block and leave it two wheel drive til the spring
then convert it
I think I want that front clip after you decide to part it out :) Lemme know I could bring my torches and we could do it in a day.
1 - 17 of 17 Posts
