I was wondering what after market joints for the 60 are actually rated for street use? I wanted the long cv's but those are offroad only
Thanks
Thanks
Anything that doesn't use bronze bushings.I was wondering what after market joints for the 60 are actually rated for street use? I wanted the long cv's but those are offroad only![]()
Thanks
then you should know what to buy to fit your application. :thumb:And yes I know you don't need it for michigan wheeling, but I don't care.
unless you are running unit bearings why cant you run an offroad only u-joint? the hub will be unlocked so the front axle would not be spinning. I dont see the problem?
blah. I forgot about that when I was thinking of it. :miff:rear steer.... aka always spinning
