I have a 2002 Dually with the 6.0 - If I let it idle for a few moments I get a dead miss on one cyl. I tried the usual, cleaned throttle body, replaced plugs and wires, but nothing worked. All I have is a generic scantool, and the truck has yet to set a fault.
Is there a common failure that one of you knows about? Do these have injector issues or coil issues? Anything else I should check before I get out my kneepads and go beg/blow to get Tech2 time out of one of my friends?
Also as a sidenote, Any tips to getting the broken f-in way too small exhaust bolts out of the head? I have a spare LS-1 that I wanted to put in another car and I just noticed it had 2 bolts broken in the driver's side head.
Thanks!:sparks:
Thanks!:sparks:
