stripped unit bearing bolt head. 92 Cherokee d30.
Obviously there's is very little room there and not enough room for vice grips.
Ideas?:miff: :miff: :miff: :miff:
You mean 6 point socket?Use a grinder & cut the whole head off. Pull it out with the stud still in the bearing & deal with it on the bench.
Next time use a 12 point socket.
nope its a 12 point boltYou mean 6 point socket?
no he means 12 point. 6 point may be what rounded it off in the first place.You mean 6 point socket?
Yep, Weld a big nut on it and the heat will help loosen it too.Weld a big ass nut to it.
x2Use a grinder & cut the whole head off. Pull it out with the stud still in the bearing & deal with it on the bench.
that'd be ideal, but there's not enough room in there for a grinder.Use a grinder & cut the whole head off. Pull it out with the stud still in the bearing & deal with it on the bench.
This one is a 12 point, 13MM.Oooo I remember my dodge had a bolt like that 12 point 9/16's or something like that.
