Can 5 point harnesses be mounted to the floor, i think i remember seeing that guy on trucks doing it to project wildhorse. I have a 94 YJ, i plan down the road to have a full cage in which the seats are mounted to the cage, then im going to mount the harness to the cage. For the time being, my 5 point seats are mounted to the stock seat brackets and those are mounted to the floor. I know the rule if the seats are mounted to the cage, the harness has to be mounted to the cage in case of seperation from the body, etc... Now the only issue i see is the the shoulder straps right now. Can i mount those to the floor? Or, do i need to mount them to the roll bar since the roll bar is currently only mounted to the tub? But then if the bar seperates from the tub that could cause a problem with the seat being mounted to the tub.
If i mount this to the tub, i will be reinforcing the mounts with wider flat sections of steel to strengthing the mount as opposed to just putting the bolt through the floor.
