I swapped transmissions in my 96, gmc c1500 with a 5.7 and now the gear indicator light on the dash isn't working. I had to replace it with a new one(second new one actually the first the prongs where bent inside). I've tried reinstalling it according to GM instructions and all I can get is a light in the OD position, before re adjusting I had a light in the N, OD, and 1st positions and it would flicker on in the neutral position when shifting from R to P. Any suggestions? It does seem to be in the correct gears and shift fine in the case it's just not lighting up the dash.
Thanks,
Kurt
Thanks,
Kurt
