Well deserved upgrade! Now the wife will be happy she doesn't need to keep telling you to buy it!
It's pretty well set and doesn't need much other than little changes to make it my own. The ARB and cutting brakes should be installed within the next month and then it's wheeling time. The front axle shafts are Yukon and I am doubtful they will hold up. So I see Branik 300M shafts in the future.That thing is siiiiiiick! What are your future mod plans?
I originally thought RCV was the way to go. But after seeing some discussion on dedicated rock crawling FB pages, it appears that the guys out west are not big RCV fans. Some is due to service, others due to available replacement parts quickly and others simply don't think they hold up as well.Sounds nice to be able to jump into something and not have to worry about many upgrades. Look forward to the updates! Are branik 300M better than the RCV stuff???
:EDIT:
wow.... those are some BEEF!
I don't need any better steering than I currently have. My tires rub my links right now. I can't find the old school code for a D60 joint. Everything comes up SPL55-3XBranik has 1480 and 1550 4340 and 300M shafts, and can support more angle than RCVs. They are making their own 1550 joints, too. If you want more than 45* steering angle then it's an option.
1550 spread makes the loads ~30% less on the joint and ears of shafts
no change to shaft strength except at yokes
Customizing it.Just bought it and already wrenching on it. I love it!
Not much to show in the way of pics but I've been working on it steady. The new cutting brake is installed and plumbed. I never trusted the oil pressure gauge because it has read high (80-ish) since I bought it so I replaced it with a good old fashioned mechanical gauge. The master shutoff switch was in the console which was burdensome and also unavailable for an outsider to shut the rig off in case of a bad rollover. So I bought a new master switch to be mounted in a visible location. My new trans is here and hoping to install it this weekend. So, with luck, it may be back together within a couple weeks.
What did you get for the new master switch? One of the next items I need to buy for my buggy. Was thinking about the Flaming River with the secondary alternator terminals.Not much to show in the way of pics but I've been working on it steady. The new cutting brake is installed and plumbed. I never trusted the oil pressure gauge because it has read high (80-ish) since I bought it so I replaced it with a good old fashioned mechanical gauge. The master shutoff switch was in the console which was burdensome and also unavailable for an outsider to shut the rig off in case of a bad rollover. So I bought a new master switch to be mounted in a visible location. My new trans is here and hoping to install it this weekend. So, with luck, it may be back together within a couple weeks.
Nothing fancy but it's the one that @JohnnyJ put in his 4500 car about 10 years ago and is still working.What did you get for the new master switch? One of the next items I need to buy for my buggy. Was thinking about the Flaming River with the secondary alternator terminals.
Lots of things are changing. So far;Just bought it and already wrenching on it. I love it!
I want to run it for a season as-is. Depending on performance, rear steer may or may not happen.If the Trans is out you have the drive shaft out already you might as well tackle that rear steer project
RBB
ThanksBeautiful rig! Glad to see it'll be put to good use too.
Thanks for the link! That one is way cheaper.Nothing fancy but it's the one that @JohnnyJ put in his 4500 car about 10 years ago and is still working.
Speedway Four-Post Battery Disconnect Isolation Kill Switch
Battery disconnect switch for safety and theft protection. Required for use with alternator cutoff by NHRA. Battery shut off switch can be remote mounted or where specified for saftey and convenience. This battery kill switch featues a die cast lever.Rated at 180 amp continuous, 1000 amp...www.speedwaymotors.com
Always need projects to work on 😁Lots of things are changing. So far;
-rehabbed the front ram mount and truss
-installed a dedicated power steering cooler
-relocated the trans cooler + thermostat on/off
-relocated the main fuse/relay panel
-added a dedicated solid state fan relay for motor and trans coolers
-swapped the t-case cable shifters to my preference
-relocated rear light bar
-cutting brake
-New ARB rear locker and ARB compressor are on the shelf ~ plan to install them probably in late March/April.
-Swapped out the 3x4 harness for new PRP 2x5's.
-Swapped the 8274 off of my YJ onto the Willys
-Installed 12v guy in-cab winch control
-Added HAM radio
-New 42 Reds are ready to go on (will keep the 43 SX's for sand/snow)
