1 - 17 of 17 Posts
Red Dragons!
Discussion Starter #1 (Edited)
WJ 4.0 block and crank, there is a nick in one of the bores up near the top, I can text a close up if you are interested, includes all the rods in the pic-the pistons are junk-$50
Two heads-both are early wj-nonTUPY- need rebuild or use as cores-$40 each
4.2 crank-light surface discoloration from sitting in the barn-$50 sold
Located in Fenton, all prices are obo.
I might want that 4.2 crank so please don't scrap that yet. I have to get my engine torn down to see if i spun a rod bearing.
Red Dragons!
Discussion Starter #11
What year is the wj block?
Would it clean up with a .030 bore job?
Not sure on the year, but I think its probably a 99 or 00. Probably would clean up fine at .030. Pm your number and I can send some pics, kinda looks like something is smeared on it, might be able to scrape it off.
Premium Member
Thanks for the info. You are correct on what you have. I found a short snout today that I believe will work. If something changes I will be in touch.
1 - 17 of 17 Posts
