1 - 9 of 9 Posts
Premium Member
I built a 350 for my YJ, but there are a couple of problems, so I'm parting it out and selling it as machine-ready, because it will need to be bored and have cam bearings installed. The rods are mismatched, so it wont turn over whith the rod bolts torqued. I would like to keep the new pistons that are on the bad rods so i would like to get $150 for the good clean block, crank, caps and set of used but matching heads.
Premium Member
Discussion Starter · #2 · (Edited)
Now priced at $100 or 5 cases of Budweiser and includes:
New flexplate
Serpentine brackets
Ps pump
New alt
Waterpump
Ac compr
Valve covers
This is in the way, I don't want it and need it gone.
BUY AMERICAN
are you serious about the bud?? if so 5- 12packs, 24 packs, or what ?? and what did the engine originally come out of?? what year of chevy
Premium Member
Discussion Starter · #5 ·
The engine came out of a 90 C2500. I figure a case of beer is $20, so if you want to pay with cash- $100, with beer- 5 cases.
Premium Member
Discussion Starter · #7 ·
is this a roller motor?
No, TPI's and Vortecs were roller, this was just a flat tappet originally. The roller rockers shown on the heads are for a pre-86, which I found out will not work on these TBI heads due to the amount of valve tip above the lock. This will come with a set of factory stamped rockers if someone needs some.
1 - 9 of 9 Posts
