this jeep is pretty much ready to go, it has a few loose ends that need to be finished up but could be also driven the way it is, it needs a passenger rear door handle (opens from the inside but the outside sticks), could use a new set of shocks (they are not blown out but they are rusty), also needs a rear gate latch, it does open from the inside but not from the outside
the jeep sits on about 5 1/2 inches of lift, the fenders have been cut and came out pretty good,
I cut the rockers out with the intention of building rock sliders but just ended up undercoating from the door line down and painting it black,
the interior has no carpet and has a few missing plastic pieces, the drivers side floor has approx a 2 quarter size rust hole and thats it for the floor,
the jeep also has a rear tire carrier that swings away, i just havent had time to mount the spare on it.
the jeep has approx 140,000 miles on it and runs like a top, i just put new pads, rotors, and calipers on the front(it might need rear shoes soon) i re-did the brake lines that were rotted, i also just rebuilt the transfer case(a shift linkage broke inside the case) ever since that the speedo stopped working but it could just be the speed sensor in the t-case.
ill try to put pics up but if you want them now ill txt you some just pm me your number
asking $2600.00 OBO
thanks, mark CALL FOR FASTER RESPONSE....(616)889-7477
note: WILL COME WITH 50% BFG MUD TERRAINS 33X12.5r15
asking $2600.00 OBO
