161 - 180 of 562 Posts
Discussion Starter #162
thank you going to start on bed cage soon so i can get shocks mounted up and have her sitting on her own weight again !
You thinking about tying the top of that truss into the top bolts of your diff cover to negate peel on the top plate?
Looks good, you're going to have a ton of travel available if you want it!
Discussion Starter #164
yes i have a plate for it and a pinon bash guard just haven't put them on yet. need to modify it a little bit still after i gear the rear end one of these days i will install them also
Discussion Starter #169 (Edited)
what's the vertical separation at the frame end and axle end?
front is set at 4.25 right now, going to move it up the top hole witch is 5.5, but i know its more at axle end, the front link mounts are the dual adjustable mount from ruff stuff, but i do not care for the upper mount part of it i might make new ones for the upper links and go higher and shorter link we will see. it cycles decent but could be better i will fine tune it in ones i get shocks mounted and it siting on its own weight
Wheeler-less
Nope. Photobucket just updated their terms of service and 3rd party hosting is going bye bye. Shame. Lots of good threads are dying.
