TORQUE SPECIFICATIONS
Description Nm lb-ft lb-in
Differential pinion shaft lock screw 27 20 -
Differential housing cover bolt (Grade 5) 47 35 -
Differential housing cover bolt (Grade 8) 61 45 -
Bearing cap bolt 108 80 -
Pinion nut 339 250 -
Stabilizer bar clamp bolt 23-32 17-24 -
Axle U-bolt nut 221 130 -
Axle vent 3 - 27
Center bracket bolt 17 13 -
Lower shock absorber nut 79 58 -
Brake caliper anchor plate bolt 173 128 -
Driveshaft flange yoke-to-pinion flange bolt 112 83 -
Differential ring gear bolt (Grade 8) 176 130 -
Differential ring gear bolt (Grade 9) 298 220 -
Oil filler plug 27-41 20-30 -
Differential case bolt (except Grade 9/180) 92 68 -
Differential case bolt (Grade 9/180) 129 95 -
