1 - 1 of 1 Posts
Discussion Starter #1
It was crashed into a tree. Only cosmetic doesn't leak any fluid. Parts installed in the last 2000 miles. Rack and pinion, upper and lower ball joints, outter tie rods, shocks and sway bar links all the way around. Power steering pump. Water pump, thermostat housing, fuel pump, spark plugs, belt tensioner, belt idler, belt, tires have 70% tread left,battery,starter. This explorer is mechanically sound and I would drive it anywhere. It has auto 4wd. And selectable 4wd hi and 4wd low. Runs and drives great. Shifts good also has around 210xxx on it. Asking 700 obo call or text at 2488802435 and can get better pictures
1 - 1 of 1 Posts
