1 - 20 of 51 Posts
In Da Faaaaaace!!!
1988 YJ
to what Ohm stable is it?
your amp is set like this for the speakers:
L Chan R Chan
Take the - from one side (L or R), than take the + from the other side. If you choose to take the - from the L, take the + from the R, and visa-versa.
This will Bridge the amp taking power from both channels into one. This lowers the Ohm load so less resistance = more power. It will get hot and if your amp cannot support 2 Ohm load it will shut off if it has a thermal switch...if not you can ruin the amp.
The Man Myth And Legend
L Chan R Chan
x2
sim sim balla bim
Discussion Starter · #8 ·
all so make sure the sub will handle the power of the amp when brigde cuz if not you could do some damage to the sub
When you bridge an amp does that double the power? If so I may have to look into a different Amp. The amp is rated for 1000 watts 2x500. And the sub is rated for 500 watts. Your thoughts? I mainly got it to drive my neighbor crazy, she is a royal bitch with a big mouth:tonka: In fact I think she is a man in a bitch body. Well, not the main reason I like the sound too, but cannot wait to piss her off.
well if its a good amp when u bridge down to 2 ohm stable itll prob run around 650 rms 1000 watt peak . so yeah the sub u have will prob smoke..but u could also turn the gain way down...if its a cheapy then watt rating is prob way off
Uggh
Ok, looked at the sub. The only thing it says is 4ohms.
if it is a 4 ohm sub bridged the amp will see a 2 ohm load speakers are not ohm stable
Ohms is a measure of resistance there are so many ways to run speakers in parallel and series etc but with the one sub you will be fine just take your time adjusting the amplifier
It is recommended that you turn your stereo to 3/4 volume while adjucting the amp (if you normally listen to it louder turn it to that point )
Recovering XJ owner
You should be fine ... ex: If you want to bridge an 8ohm sub your amp needs to be 4ohm capatable, so in your case a 4ohm sub will work with a 2ohm capable amp.
Just do it and start out by keeping the gain down ... once you have it dialed in turn the gain up to where you see fit. Short/fat ground cables are your friend. Also best to run a fuse block and/or power interupter closer to the power source (battery).
Recovering XJ owner
:sonicjay: x2- I'm slow
sim sim balla bim
Discussion Starter · #14 ·
Its a flebay special it is a Saga. I payed 60 shipped figured I would try it for that price.
seein that the amp u have was only 149 brand new.. its watt rating is 410rms bridged at 14.5 dynamic power..which itll prob never see in a normal car or truck.. turn the gain down a lil u should be fine..or go buy a sub thatll handle 800 and crank it up..
Uggh
volts x amps = watts IIRC so 12 volts 40 amp fuse (guessing) =480 watts rms lol not gonna see that out of a cheepie tho prolly 300
1 - 20 of 51 Posts
